Page 16 of 29
FirstFirst ... 6 14 15 16 17 18 26 ... LastLast
Results 451 to 480 of 841
    Sep 2005
    Darkest Peru
    Originally Posted by z1269925944 View Post
    Originally Posted by doctorm View Post
    I've been trying to gets some things from MGM+. When I play the videos 720p is the limit. I have found though if I simply take the .m3u8 and rename it as 1080 or even 2160 the mpd exists (playlist_2160.m3u8). I know the keys aren't the same but is it possible to force it to play in order for WidevineProxy2 to get the key or do we again need L1 CDM?
    N_m3u8DL-RE "https://epixhls.akamaized.net/movies/_drm/fmp4/gladiator-ii-2024/bb60ef9f-f68f-45eb-8d46-868d33941ca0/fa6465d2-6af7-405e-ab53-b9e51f13c1ea/playlist_720.m3u8" -H "User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/135.0.0.0 Safari/537.36" -H "Accept: */*" -H "Origin: https://www.mgmplus.com" -H "Referer: https://www.mgmplus.com/" --key 7b7e16c5465c464cb75970c40a708bb3:74593d71c0025da39baf16498db43a68 --use-shaka-packager -M format=mkv
    Edit: The above is just an example that has a 4k stream. What's my real frustration is that they have a movie in 1080p that I thought was only 720p and has never had a Blu-ray release. I desperately want to rip that.
    Edit 2: Found out this doesn't work even for the 720p version for the movie I posted above.
    I re-tested the older movie I referred to in the 'Edit' comment and found the 720p DID work if I used the .mpd link instead of the .m3u8. Not sure if that was a fluke or necessary.
    I ALSO found the pssh from the 1080p mpd file is identical to the pssh in the 720p mpd... so they use the same key. I literally just needed to use the key from WVP2 and copy the 720p .mpd link, but rename 720 as 1080 when running n_m3u8dl-re.
    Woohoo!!
    Not sure what makes the top movie's stream different from this other movie.
    extension only fetch streams that are playing in your browser, in this case MGM limited browser with 720p so you can't get 1080p/4k with browser, must use a script to get these quality
    That's what I was talking about. They won't play 1080p or higher in browsers, but the m3u8, mpd, and keys are all accessible. I was able to download one movie in 1080p, even though it isn't played in the browser.
    The other movie I posted the command for here (from WideVineProxy2) failed to decrypt even at 720p. That one went as high as 4k and I could get the keys and everything pretty easily, but even the playable resolution was unsuccessful.
    Can you d/l and decrypt what I posted?
  2. Originally Posted by doctorm View Post
    Woohoo!!
    I don't have account so I can't check it for you
  3. One more question. How can I download the subtitles files to srt? Thanks.
    https://www.nbc.com/la-mujer-de-judas/video/todos-tenemos-secretos/9000436668
  4. Can you help me please? Thax!!
    Dec 2021
    england
    use CCExtractor
    https://gofile.io/d/VzOUnh
    Sep 2005
    Darkest Peru
    Edit: Okay, here's what I've figured out for that site.
    Although the browser limit is 720p (at least for me), you can access higher .mpd and .m3u8 links.
    You need to use the .mpd link NOT the default .m3u8 with n_m3u8-dl for this site to work.
    1080p is completely accessible, just swap out the number of the playlist_720.mpd link with playlist_1080.mpd.
    While you can get the .m3u8 for up through 2160p, the .mpd seems inaccessible, and as I said, the .m3u8 fails.
    The one older movie I ripped, worked 100% and was easy. The one I linked above I was able to get the 1080p video, but the audio tracks come up with
    Error opening input files: Invalid data found when processing input.
    Mux failed
    Failed
    I don't know why, I've tried a bunch of things but I can't get any of the audio tracks successfully.
    Dec 2021
    england
    your command line show KID
    84524cc5097cd376abf9b4374cee2c25
    and you post kid:key doesnt match KID so wrong keys
    Sep 2005
    Darkest Peru
    Are you referring to my post? I'm not sure what you're referring to.
    Anyway, I've figured it out. There were three .mpd links:
    https://epixhls.akamaized.net/movies/_drm/fmp4/gladiator-ii-2024/bb60ef9f-f68f-45eb-8d46-868d33941ca0/99883912-dc5e-49c7-bfd0-e0e3c93a8bd1/playlist_720.mpd
    https://epixhls.akamaized.net/movies/_drm/fmp4/gladiator-ii-2024/bb60ef9f-f68f-45eb-8d46-868d33941ca0/3f154d15-6053-4cc5-86d0-3f0e6c8efecf/playlist_720.mpd
    https://epixhls.akamaized.net/movies/_drm/fmp4/gladiator-ii-2024/bb60ef9f-f68f-45eb-8d46-868d33941ca0/99883912-dc5e-49c7-bfd0-e0e3c93a8bd1/playlist_480.mpd
    So for anyone interested, here is how to do MGM+:
    1) Use the only .mpd links with n_m3u8dl_re.
    2) Use the 720p link that does NOT match the 480p one. It has a different key, and that's the only one that works with the audio track.
    3) Replace the 720p in the link with 1080p if you want higher resolution. 2160p doesn't work and I've yet to find any mpd link, at least not with an L3 CDM.
    4) DON'T USE shaka-packager here. It can't decrypt the audio. Everything works just fine without it.
  9. Originally Posted by doctorm View Post
    HTML Code:
    https://epixhls.akamaized.net/movies/_drm/fmp4/gladiator-ii-2024/bb60ef9f-f68f-45eb-8d46-868d33941ca0/a08634a9-254d-441a-ba3a-dcb0fbbe9a96/playlist.mpd
    here is 4k mpd, you can download directly without key.
    Sep 2005
    Darkest Peru
    HTML Code:
    I'm assuming you used an L1 to get that. Interesting that the audio track is still low bitrate stereo. Also, the playlist_2160.m3u8 has the video as AVC not HEVC.
    Edit: And it's not even encrypted? Weirder.
    Edit 2: Wow. I've pretty much discovered that CDM L3 will download and decrypt streams up to 1080p on several sites even if it isn't available for playing in your browser or in the links that WVP2 finds.
    You just need to find the correct MPD which might not even be found searching network tab of the developer's tools.
    I've now successfully done this on two streaming sites. Wish there was a way to get MGM+'s 4k mpd, but I have no idea how z1269925944 found the "a08634a9-254d-441a-ba3a-dcb0fbbe9a96" part of the link. I assume he had the site think he was using a different device to generate it.
    Is it a secret, z1269925944?
  11. This is a terrific program and thank you for making it. I remember mention of certain commands one can put in to make it even more to one's preference. If possible can someone write more about that aspect of things.
  12. Originally Posted by iamghost View Post
    use CCExtractor
    Thanks a lot!! But How Can I download in the program?? Thanks your help!! How can I in CCExtractor? I see this output setting, but how can I download? ccextractor --gui_mode_reports -autoprogram -out=srt +[input files]??? Dashboard, Add more files, I select the video but nothing... What I need to selects in the menu??
    Dec 2021
    england
    ccextractor.exe -1 -out=srt -bom -latin1 "path video.mp4"
    -1, -2 = track
    Sep 2005
    Darkest Peru
    I use a lot of the default stuff, but I do:
    --gui_mode_reports  -autoprogram  -out=srt -bom -utf8 -trim
    https://ccextractor.sourceforge.net/using-ccextractor/command-line-usage.html
  15. Originally Posted by iamghost View Post
    -1, -2 = track
    Sorry, But I Can't option this. How can I and where? Can you give me a screenshots, please? AfterI have an empty document. Image
    [Attachment 86712 - Click to enlarge]
    Dec 2021
    england
    -1, -2 = track
    just open command prompt
    [Attachment 86716 - Click to enlarge]
    Dec 2021
    england
    double post..
  18. Originally Posted by iamghost View Post
    -1, -2 = track
    Thanks, but I dont have in.cmd.txt look!Image
    [Attachment 86720 - Click to enlarge]
    Dec 2021
    england
    thats normal... cmd.txt is I create it with notepad with command line. it save me typing command line when i need it
  20. Sorry that I am so stupid. But can you help me please? How can I do that and copy your text?? Where?
    Copy full this? ccextractor.exe -1 -out=srt -bom -latin1 "LMDJ 001.mkv
    Thanks a lot and sorry! 😌😌
    Dec 2021
    england
    Thanks a lot and sorry! ����
    you making mistake, LMDJ 001.mkv is not full PATH where are they?
    ccextractor.exe -1 -out=srt -bom -latin1 "C:\user\myPC\video\LMDJ 001.mkv"
    for example:
    see yellow box, thats what i put it command line...
    [Attachment 86722 - Click to enlarge]
  22. Originally Posted by iamghost View Post
    for example:
    DNS not ok.
    [Attachment 86729 - Click to enlarge]
  23. Member
    Dec 2021
    england
    Your doing wrong again….
    Go to ccextractor folder run cmd from there
    Enter command line
    Your post #468 picture is right just add cmd on address bar not browser one
  24. How can I add cmd? I not to this before..can you help me please? Thanks a lot!!
  25. Somebody can you help me please??
  26. Member
    Dec 2021
    england
    Don’t tell me look… you look it again.
    I said open command prompt in ccextractor folder,
    Simple…type cmd on top
    Or do
    cd PATH ccextractor folder
    Add command line
    Boom your in
  27. Member
    Dec 2021
    england
    C:/users/Dani>
    Look at mine
    C:/users/xxxxxx/ccextractor>
    Cmd can read everything in that folder, your is not
    Like I say it again open cmd in ccextractor folder
  28. Member
    Dec 2021
    england
    Finally I'm home from work...
    Like i said type c...m...d... on top to open command prompt to run ccextractor folder
    [Attachment 86735 - Click to enlarge]
